bachevelle52
Active member
- Joined
- May 23, 2009
- Messages
- 43
Okay so,
Initially i wanted to design a buffer for the front end of an INA 217 based micpre built around the circuit provided in the datasheet. I believe it was PRR who so eloquently asked why would i want to stick "a gitar in a mic hole?" Thats a great question that ultimately led me to dismiss that idea altogether. So the new idea would be this: a box i can plug said "gitar" into that can amplify my signal to drive a line input.
I own a copy of "the Art of Electronics" and i've been reading and re-reading this book for years. I still don't really understand, perhaps my friends here at prodigy-pro can help. With that said, please understand that i'm not looking to get this designed for me, i desperately want to do this on my own, i just REALLY need to be nudged in the right directions.
Here are my thoughts:
1. the treatment of emitter followers in TAOE states that input and output impedances are relatively easy to adjust. Based on the given example, biased from +20V there is a voltage divider setting the base bias. The apparent input impedance is dictated by the bias divider in parallel with re -the intrinsic emitter R. They seemingly arbitrarily choose 1mA quiesent current and that is the basis for the value of Re. Then there is the issue of Rc which is stated to set the gain.
So my questions start here.
1) how do you choose the quiesent current? What does this affect?
2) Rc was determined based on what?
3) in calculations, mant times i see hfe as a term, and it would appear that 100 is the typical value used, however it is stated repeatedly that hfe dependent designs are poor designs.
I'm positive i will have 100 more questions before this is done but this should be a good start. For reference, i believe the treatment of emitter followers is towards the beginning of Chapter 2 in TAOE, i've been studying the first circuit example.
I would ultimately like to design this one bit at a time, but the total gist would be Emitter follower, to say a common Emitter stage. as far as i can tell at this point, what i need is:
1) 1Mohm input Z
2) maybe 40db gain
3) 1k output Z to drive 10k Z line input
...for now.
Any help, thoughts, ridicule.... all welcome. I so desperately want to learn this, i honetly just cant put my family on hold to spend 4 years in school.
Thanks in advance,
Ben.
1) 1Mohm input Z
2) maybe 40db gain
...for now.
Thanks in advance,
Ben.
