[quote author="Nadege"]No, it's a one bottle the fille is named MILA but it's just because I'm lazy when importing picture to my computer and I'm giving the same name to all my pictures... :?[/quote]
Your links in this thread are pointing to the MILA pictures. I found your One-Bottle pics by viewing all your uploads. So, the blue case is the MILA and the Lacie case is the One-Bottle.
A couple of things about the One-Bottle, by having the turret board on the bottom of the case, and the tube socket on the lid you've made your wires running to the socket rather long. It would be better to have components mounted on the socket or at least close. Might not be much of an issue in practice. If it's quiet, it's all good.
Also, the Edcor output transformer is not shielded, and you have it mounted on the outside of the case. Again, might not be an issue, but in a room full of interference, RFI, EMI, etc., it might be. If you put it in a rack, you will have to careful how close it is to other cases that have externally-mounted power transformers and such.
