[quote author="ioaudio"]yeah diy is not cheap - and it gets worse after some time :shock:
you didnt like the oep-input transformer - which one did you use? i made two pre#7, one with lundahl and the other one with oep, and the oep - equipped unit got more use...
building dave´s design with another tube will likely lead to a different-sounding preamp. he designed it around this particular tube, and since its a one-bottle, the kind of bottle is definately a big part of the system
you might try a one bottle with a ecc88.
-max[/quote]
#7 didn't sound bad with OEP. Compared to Tube-Tech Mp1A they were not in same league, Tube Tech was better. But DI was better on #7, it had more details and warmth. So i finished #7 as a DI. I used transformer that you suggested.
I PM-ed Dave about tube replacement. I think it is better if he tells me what to do as One Bottle is his design.
@rafafredd
I didn't use new components, layout was not very well done, power transformer was noisy (got it from old radio), tubes were old...I built it to learn how to do a proper layout on veroboard.
It is not fair to judge #7 from my results, because it was not well built.
Miha
