saxmonster
- Joined
- Jan 3, 2012
- Messages
- 534
So my receiver decided it didn't want to listen to the remote anymore. The remote is fine as I can see the light coming out of it using the camera on my iPad. So the remote is fine and I did a full reset on the receiver and still no luck.
I opened the unit up and found a questionable cap(C7002). it is leaking but not sure if it is in the power path of the remote sensor. The cap that I read about to change out is (C7008) forums have said that might be the issue but it looks fine and that is the bigger cap right next to the Tower that the remote sensor sits in. So I was thinking about replacing the sensor (U7001), The cap that I read about (c7008) and also the leaking cap(C7002).
Here is a link to the service manual if you have any ideas.
https://www.dropbox.com/s/hhs7t84rv1hn8mf/onkyo_tx-ds575.pdf?dl=0
