Stolenchild
New member
- Joined
- Sep 13, 2004
- Messages
- 1
Hi guys,
does anybody have a good idea for replacing TL074CN and/or NE5532N OP-Amps?
I have an old Rocktron RSB18 (built in 1989) guitar effects looping system which I favour over products because of the many features built to this unit. The problem is that is has a relative high ground noise level which I would like to lower.
In each loop there is one TL074CN and a NE5532 for amplifying signals. The noise rises the more loops are activated.
I have been reading some articles on such subjects and the more I read the more I get confused if there is a suitable replacement possible.
When I replace with higher current op-amps i blow my power supply. But those with higher current consumption have faster slew rates which are good for sonic transparency.
As I am no electronic engineer this is above me. Has anybody some suggestions where I can learn more about such issues?
I built myself an Gyraf1176 which works fine so I can solder if I am told which part needs to be where.
Or can't such things be answered generally?
Thanx in advance,
S
Thanx in advance,
S
