Samuel Groner
Hi
I need a test jig to measure opamps for their DC open-loop gain and DC open-loop gain linearity. This is usually done by amplifying the error voltage at the inverting input by means of a voltage divider as shown e.g. in OP177.pdf (page 9) or AN-1485.pdf (20 MB).
What I need:
* measure gains from 60 dB to 180 dB (in four decadic ranges)
* trim opamp offsets up to +/-20 mV (in three decadic ranges)
* output loads of 10 kOhm, 2 kOhm 200 kOhm as well as external load
* supply voltages up to +/-40 V
* optional low-pass filter to reduce noise
And here's what I've come up with: DC_gain_linearity_tester_r1.pdf
The +/-15 V supplies to bias the offset voltage trim circuitry are only used when testing at supply voltages below +/-12 V.
Any comments, additions, corrections? Thanks.
Samuel
What I need:
Samuel
