No, I'm just saying if the first opamp is different than a 2520 it must be a 2510. I said that up there, when he said the first DOA was the problem I asked if it was like a 2520 or not. I've never seen a 550b inside, only 550a.LRRec said:Are you sure the 550b has a balanced input?
The pair I had from the 90's were unbalanced like the 550a. No 2510, just 2520's.
hello, I have a 550B with a non working band (low mid) I took it apart to find something obvious, but I did not see anything starnge, maybe a defective switch or an open path ?anyone can shed some light on this problem ? I could not locate a schematic, would be very handy... thank folks
Possibly a faulty capacitorhello, I have a 550B with a non working band (low mid) I took it apart to find something obvious, but I did not see anything starnge, maybe a defective switch or an open path ?anyone can shed some light on this problem ? I could not locate a schematic, would be very handy... thank folks
Yes, very possible. I think every "vintage" 550 (A,B, the mysterious old "550M", not the recent "Mastering" version) that I have ever been into has had electrolytic caps in very bad shape. The 16v decoupling caps on the 16v supply rails are virtually always toast. Replace those with a higher voltage cap, 25v> (and make note of the orientation before your remove them! I have a vague recollection of the "+" marking on either the parts overlay or the actual circuit board being incorrect in one position).Possibly a faulty capacitor
THe 550A-1 wasn't a mistake, it was an attempt from API, right before they went out of business to make the A cheaper. At the time everyone had forgotten the tech behind a passive filter, where you had to keep the over all impedance constant if you wanted the frequency to stay the same. That is why just about every EQ in those days was a Proportional Q circuit, the constant impedance altered the Q. When I started at API (Datatronix) they inherited the -1, not realizing that it wasn't proportional Q, and started selling them. When Sunset Sound sounded the alarm to us, I pulled out the old HP spectrum analyzer and quickly realized that they were fixed Q. All of us, including Saul dropped our jaws. That brought about the re-design of the A with the connectorized switches, just so they could be tested. We also decided to make the buffer card the same pinout as the TL084 op-amp so you could swap one out for testing or in an emergency.The page also mention 550a1 with a mistake, it wasn't meant to be cheaper, IC opamps where an experiment, believing the IC opamps at that time were better than when 550 was released so they tried to, they found the sound wasn't as good as expected so they came back to discrete, all was socket and IIRC the PCB of those and 550a of that time where the same, they were designed to be any of those.
JS
Hardly ever a faulty cap, it would still work to some degree, most likely the Sansie 6 pole switch. They are getting to that age. Could also be a buffer, but that would tale out 2 bands. You can fine schematics if you search, slight possibility that it could be one of the resistor ladders on the ceramic. If you have a microscope camera, look at each terminal and see if one has come loose. They can be desoldered.Possibly a faulty capacitor
