pucho812
Machine Otari mx-55 1/4 2 track with center time code. center tc track not being recorded.
got an MX-55 that a friend is using as a mix down deck. It was aligned and was working quite well until yesterday. Yesterday, when recording to it and monitoring off the repro head I get the sound of static in one channel only(the left side) of the 2 audio channels. Static is random and will be present at all times. If just have the machine in record and monitor off repro head and am not sending audio to it, I still have the random static. I have so far swapped cables and no change. I swapped audio cards around and the sound didn't change, it's still on the left side. Tried different tapes both fresh new reels and still the random sound of static. Could it be the heads? it's the only thing left I can think of as there really isn't much else in the audio path
Oh yeah and before anyone asks this is happened before and after we used a hand demag on the heads.
O.k. so searching lead me to this.
http://soundcloud.com/blungo2/march-tape-noise
that is it that is the noise. In the recordings it's louder then the mx-55 I am working on but that's it. Further searching has lead me to an answer that it could the relays on the audio cards. But that would suggest that it would follow the card when swapped.
might be time to do a head relap.
