Hi there,
my first post here and maybe this is a dumb question, maybe I should be posting this on an Apple/Logic forum, then again maybe it's relevant to those of us building outboard gear projects for use with computer based recording set ups.
I'm recording in Logic Pro 8 on a iMac 2.4 Ghz Core 2 Duo via an Apogee Ensemble using outboard gear, a mixture of off the shelf stuff and homebrew projects, however when I come to EQ and Compress prerecorded tracks or master stuff using the outboard I'm faced with a bit of a snag. I've got my tracks sounding good through the gear, then I wanna rerecord the processed tracks back into Logic but what buffer size to use?. 128 takes away the top end, 512 takes away the bottom end, 256 is a compromise. Clearly I wanna go out at 1024 and come back in at 64 for maximum quality.
Am I missing something here, I've Googled this problem about a hundred times and can find absolutely no reference to this so I feel like the only person on the planet who sees this as a problem. I've tried rerecording at 256 and adding a bit of top and bottom eq, but it's too much trial and error for my liking. My solution at the moment is to rerecord at 128, 256, and 512 and mix them together, but it's still a compromise and takes up loads of track count. I have read some people saying that there is no difference in sound quality between the buffer sizes, this is clearly not the case to these tired old ears.
What do you pro guys or anyone else using Logic do? As I said, maybe this isn't a suitable topic of conversation for this forum, but it doesn't matter what grade of caps or flavour of iron I use if I'm losing it all in the bounce.
