Whether you calculate it yourself, use the tube chart, or copy what someone else did, the "optimal" primary OT impedance depends on the plate voltage.
My 1967 Fender Vibrolux reverb OT has a primary impedance of 4400 ohms (into 4 ohms). Plate voltage is ~440.
The 1959 Sylvania Technical Manual suggests primary impedance values for 6L6GC class AB1 with 400V on the plates: 6600 (34W output); with 450V 6000 ohms (50W output).
-Jon
