soapfoot
This seems like it ought to be an easy question, but I'm not sure how to figure it out and would appreciate any help!
Building a pair of MEQ-5s, I've tested and marked all of my capacitors for outside foil. I just want to double-check my reasoning of where outside foil should be connected (apologies for the quality of the attached schematic).
Thanks for any insight!
- The "mid dip" section is easy--all of the capacitors connect directly to ground on one end.
- For the "high boost" section, all capacitors connect directly to "VOUT" on one end, which directly couples to the grid of the 12AX7 in the following stage. So I'd assume to not connect outside foil here, and to connect the outside foil of each capacitor to the switch instead (where it would have a path to ground through the inductor coil and a few potentiometers and resistors). Seem logical? I'm unsure here
- For the "low boost" I'm even less sure. The input transformer is a 600Ω:600Ω (Triad HS-56), for the record
