Panasonic electret capsule info ...
gentlevoice1
Aarhus, Denmark
Hi  :D
I've heard that here in this forum some people have made very good microphones from Panasonic electret capsules. I'd be very interested in more information about:
- which models are considered the best capsules in terms of sound quality, but also those that may span from close to DC and as high up as possible in frequency,
- How to modify the capsules so that they sound their best,
- Suggestions on how to design a power supply and audio amplifier for the capsule (enabling an output going down to preferably 1 - 2 Hz),
- Where to source the Panasonic capsules (also, I'd be very interested in buying spare ones if one has some for sale. I'll be needing ~4 capsules).
- other information relevant to building with these microphones
Hope you can help with this - suggestions are appreciated  :D
Best regards,
Jesper
P.S.: If there are other electret microphones with a better soundquality I'd be very interested in hearing about this. Particularly microphones with a better signal-to-noise ratio which is important to my application.
I also just found Linkwitz' webpage on modifying the panasonic electret microphone.
gyraf
Staff member
Moderator
Aarhus, Denmark
If noise distance is a primary consideration, you probably won't want to use electrect capsules...
Jakob E.
gentlevoice1
Aarhus, Denmark
Hi Jakob,
Thanks for replying. My source of inspiration is Earthworks microphones and although I am not looking to copy them I'm interested in microphones that go up hign & low in frequency and have low noise. Do you think larger size electrets will be a better solution e.g.  like the Transound versions?
See e.g.: http://www.jlielectronics.com/transsound/electrets/tsb-120a.htm
Regards,
Jesper
abbey road d enfer
Moderator
Marcelland
There's a direct relationship between diaphragm size, HF extension and intrinsic noise. You can't get 40kHz response with a large diaphragm. You can't get 12dB self noise with a 1/4" diaphragm.
A 4x4 array of 1/4" would get you almost there.
LF response of omni electret capsules depends on the built-in electrical HPF constuted by the capsule's capacitance and the gate resistor.
Cardioids are inherently acoustically high-passed.
gentlevoice1
Aarhus, Denmark
Hi Abbey Road,
& thanks for outlining these parameters. I know that this is so, however, have not heard very good implementations of electret mic microphones (and various capsules) so I have no reference as to how they (with very good electronics) compare to high end capacitor microphones (as different as they may be). I'm looking for an outstanding capsule - can electrets be that?
If you or others here have experience with this I'd appreciate hearing about it.
Greetings,
Jesper
gentlevoice1
Aarhus, Denmark
Hi Sredna,
& thanks for the tip ...
I find that I know now what I need to know so unless others would like to continue the thread, I will leave it now.
Greetings,
Jesper
bruce0
Boston
I have had some good luck with the attached circuit for electret capsules.  I have used directional panasonic capsules as front of stage boundary mics, and I have used the same circuit with Countryman ISOMax mics (I found a cheap one on ebay for wireless use, and build one of these to make it wired. It is small, fits in a small box or even a tube if you lay the electrolytic caps down
Basically it takes a 3 wire capsule like you get from a countryman isomax (which I think is just what Linkwitz does to the panasonic capsules) and you use it as a phase splitter for a Schoeps style circuit. Works pretty nice.
Several people in other threads have asked how to bias one of these mic's, without buying a $70 mic preamp head... well this works.
