This bootstrapped-rails output is based on two main things: the King/Watkins article in EDN, and the @KA-Electonics.com update of the MCI 2003 with a current-boosted back end, detailed at Pro Audio Design.
With this, I’m basically saying “you’re already surrounding an amp with parts, just do it with a dual and split the increased load.” The goal is to provide a fairly cheap, very low noise +24dBu single ended output, with a low Iq and parts count, in an otherwise dual 15V environment. @thor.zmt lobbied me successfully toward this in my thread about loading and THD.
The amp doesn’t have to be an OPA1602 — most any dual whose amps can push 22.4mA at full output will do. It could easily be an OPA1692 or OPA1678. ADA4075-2 would perform nearly as well as drawn, but maybe Vcc and Vee would need to be a bit higher. The Rf/Rg are chosen for 2.5nV/rtHz, but are of course scalable. I forgot the BAV99s at the output, just imagine ‘em there.
Questions:
• Could anything be done better/simpler?
• What would be the best choice in SMT for the NPN and PNP? SOT. I am not sure we need such a high performer as the ZTX851/951 here. But if those do have SOT equivalents, I’d love to know.
• What voltage do the amps see - +/-15.3V or thereabouts?
• If you’re doing a board with a bunch of these outputs on it, you’re bound to start loading the supplies. What happens if you multiply the supply dividers by (say) 5x or 10x in ohmic value? Higher source resistance at the bases, surely. Does the noise matter? At what point do you start to have to take a closer look at the PSRR of the amp? Any advantage to using MOSFETs at these low currents?
Thanks!!
Questions:
Thanks!!
