Hi Guys,
i was just wondering what you guys used for Patch labelling, Whatever 96 or 48 points, i need it for 48 points but just curious about the Stripes.
I got that Neutrik program that helps doing them, and i also found some Excel spread sheet template, but it was not aligned at all.
Anyway got myself a way to do them using the neutrik program and Corel for packing all needs on an A4 paper.
I found that it could also feet an A3 (a little short but not much) and just need to cut the stripes and no need to join whatever...
and fill the space on the big A3 with different colored stripes and so to be able to modify existing labelling on sticking small pieces or a whole strip and just write on it....
I guess if i want to make it cheap i'll just use A4 stickers paper and voila, but having the paper to be thick could be better, so maybe photo glossy paper and add double sided tape?,
anyway i'm curious of what you guys do most of the time, maybe there's a better way of doing them?
Thanks for the feedbacks
