Siegfried Meier
Hey guys,
I've been wiring up a few TT solder bays the last few days and had a quick question. We've got snake lines on the bay half-normaled to the mic preamp inputs, and a buss bar is connecting all the grounds together for all of those.
Now, I'm wiring the mic preamp outputs to the inputs of the Digi converters, also half normaled, but I'm not sure if the grounds should be joined in a similar manner, or if each top TT connector (Mic Pre output) should just be grounded to each bottom (Pro Tools Input) via the normal cable.
http://www.caneaudiosystems.com/TL_theassemplyPT_2.html
I've used punchblock style in my studio, and I can't recall if the grounds are internally connected on those, which is quite common on some of those ADC's.
Any info much appreciated.
Sig
Sig
