Family Hoof
How do you decide when to use thermals? In case anyone is not familiar, it is the concept of connecting solder pads to a common plane indrectly, using small traces instead of just having the solder pad be part of the plane. I've always thought this was to keep the plane from sucking all of your heat while soldering to pads on it, but someone should correct me if I'm wrong.
As for me, I have been using and enjoying them but sometimes I worry that it'd be better for signal strength to have all pads fully connected to the ground plane.
