Pcb reddi (30cm large) (finish)
Bernardo
hi i have 2 clone reddi pcb units, they work perfectly. They are ideal for mounting in a 2u box rack.
Pcb double,two faces.
The overall build looks rather dangerous to me. The safety ground pin of the mains IEC inlet is not connected to the chassis.
Hello friends, thanks for the constructive criticism, the image is that of the unfinished project. I will post an image of the construction of the project. Thanks a lot
the output transformer winding of the heaters is 6.3v not 6.2
No voltage regulator installed, meter and pot not wired, looks mid-build to me!
according to the reddi groupdiy thread the regulator is not essential, in fact this pcb works fine without it. I have built other valve projects even without rectifying the heater windings, only deriving one side to earth and they are very quiet, advice from very popular people on this forum that I learn daily thanks to them. a greeting.
