CJ said:any Peavey engineers out there?
what do these diodes do?
(circled in red)
bonus question- 5 pts - what about the diodes under the voltage regulators?
This was a bit of a myth... and probably used to discourage people from adding too much output capacitance. For the output side of a regulator to discharge back through to the input, there needs to be a path to ground for that current to flow into. A reverse biased rectifier, and reservoir cap is not much of a load on the input side.Audio1Man said:This would protect the voltage regulators from failure from reverse voltage. There maybe some other circuity connected that they needed the diodes to protect the voltage regulators.
I would bypass the regulator with a reverse diode. The output regulated voltage may be held up with large storage caps upon turn off and this would back bias the regulators and cause silicon failure.
Duke
Audio1Man said:I would bypass the regulator with a reverse diode. The output regulated voltage may be held up with large storage caps upon turn off and this would back bias the regulators and cause silicon failure.
JohnRoberts said:They're both part of the same strategy... If you go into the way back machine, there used to be a problem with early 3-terminal regulators latching up if one regulator was reverse biased at start up. The diode in the ground leg and across the supply simply prevented that latch up mode. This was more of an issue with half wave rectified power supplies, but once bitten some engineers keep putting in these parts, until forced to stop. Having production products that randomly latch up in the field, leaves a lasting impression on mass market design engineers (sometimes even leaves a scar). :'(
I had to just about threaten an experienced analog engineer in my mixer group to stop adding those diodes because they were no longer needed. I told him to prove to me that they were still needed , he couldn't (but he sure tried) so he finally stopped using them. The 4 diodes were not that expensive, if they actually did something useful, but if not, its just throwing pennies on the ground and adding more parts that can fail or be assembled wrong.
His name was Jack... a really brilliant engineer but he never took my word for one single thing... 8) 8) I respected that, I could have used more engineers like him.
Long ago, I stopped worrying about the brand of these regulators. They are so well proven there is almost no practical difference, unless they are used at their limits. I'd go for the cheapest available from a reputable distributor (Farnell, Digikey, Mouser...). Along the years I have used Fairchild, NS, TI, ST, JRC, and couldn't detect any significant difference.CJ said:had a NTE959 minus 18 volt reg get shorted to ground with a screwdriver for a split second,
this device is no longer working, short circuit protection apparently not a strong point with these parts,
better check evilbay for some National Semi old stock,
ST? they are OK i guess, TI? jury still out,
Would need high-current Zeners for this application. Lots of heat.CJ said:best short protection maybe the old resistor-zener regulator?
Zeners are über-noisy, need huge caps.maybe less noise too, or not,
This article just confirms common knowledge. What it doesn't cover is the importance of noise currents, that require very thorough design of the "ground" track circulation. Remember that these regulators (particularly 78xx/79xx) rely on brute force for noise control - the output cap discharges all the noise currents into "ground". Noise currents must not be allowed to mix with audio "ground".here is a blurb on regulator noise vs batts etc>
http://www.tnt-audio.com/clinica/regulators_noise1_e.html
abbey road d enfer said:Long ago, I stopped worrying about the brand of these regulators. They are so well proven there is almost no practical difference, unless they are used at their limits. I'd go for the cheapest available from a reputable distributor (Farnell, Digikey, Mouser...). Along the years I have used Fairchild, NS, TI, ST, JRC, and couldn't detect any significant difference.CJ said:had a NTE959 minus 18 volt reg get shorted to ground with a screwdriver for a split second,
The whole series of 78xx/79xx is notorious for the inefficiency of their short-circuit protection, particularly the 24V types.
I like to joke that consoles (and power amps) are the hardest "simple" circuits to design. I've run into funny console power supply behaviors before. But never in the lab when you can easily tweak them... You can't really test them properly without fully loading a frame (36x24).abbey road d enfer said:I guess I was just answering CJ's worries about reliability. Indeed, noise issues are a different matter.
I found early that on-board regulators in mixers were a major PITN; indeed they test a console designer's ability to implement a sound ground circulation scheme.
I was bred on on-board requlation; it was deep soul-searching that converted me to using protection resistors.
I once had a quite heated argument with Doug Self, who had designed a console PSU on the basic design brief of Volts and Amps per rail. Indeed the PSU would fire correctly one time out of 10. A console is a pretty complex and vicious load, like a huge capacitor with a bad case of DA (Dielectric Addiction)JohnRoberts said:I like to joke that consoles (and power amps) are the hardest "simple" circuits to design. I've run into funny console power supply behaviors before. But never in the lab when you can easily tweak them... You can't really test them properly without fully loading a frame (36x24).
Voltage regulators, by definition have an inductive reactance, just waiting to sing with the capacitor-next-door.One early console power supply took off and started singing at 960kHz in sympathy with a nearby AM radio tower (in VA). This later 3 terminal regulator noise didn't show up until well after the console was in full production. Either Motorola tweaked their regulator design, or purchasing changed vendors to save a penny. Either way the buck stopped with me to get the console quiet and the production line back running again.
My singing PS problem was more an issue of too much compliance between a clean ground and a dirty power ground. At the moderately high frequency of 960kHz the wire inductance in a 7' wide console was enough to form a resonant circuit...abbey road d enfer said:Voltage regulators, by definition have an inductive reactance, just waiting to sing with the capacitor-next-door.
