thanks PRR! saves me a month of rehashing RDH4,
yeah Fender is pushing it with those 220K grid resistors in the twin Reverb, (quad 6L6 amp)
this Peavey inverter circuit does have a good Presence circuit, that cap in series with the pot gets rid of the pot scratch and reduces noise quite a bit also,
changed it to a 1.5 uf non polarized and it sounds great,
also changed 100K feedback R to 47K like Marshall uses,
this amp borrows the Ampeg SVT grid stoppers, using 47K instead of typical 1.5K,
helps blocking distortion and gets rid of a little harshness as high end roll off/Miller C comes down a bit,
how much gain will I lose if i bypass that second 12AT7 circuit?
47K plate resistors are used in Fender Pro Reverb inverter, which is a good amp, so we will give that a try,
Macintosh also used the two tube inverter circuit, wonder if Peavey borrowed this concept from them,
looks like Fender also has the cathodes in the inverter sitting near the spec limit,
page 138 has some stuff on inverters, Crowehurst Hi Fi Circuits>
(use fullview to read)
https://www.scribd.com/doc/59036351/Hi-Fi-Circuits-Crowhurst
