That isn't emitter degeneration (which would be two resistors, one in series with each emitter) but setting the bias current of the LTP lower which will also shift the dc voltage of the Grid(?) resistors higher. (I am not the tube guy)if you guessed increase emmiter degen resistor, you were right!
4.7K > 6.8 K did the trick.
collectors at 105 which is about as up close and personal i want them to get to 525 vdc.
waveform good, ship it. after i figure out which colored knobs go where.
i bet Peavey gain selected/matched those transistors for the 4.7 K circuit.
still do not know why the + 16 v supply is connected to the base via 10 k.
full schemo>
