gomet
New member
First Post ever here! Hello!
I'd like to upgrade the Peavey VMP2 with new, better caps and while searchin the internet I found a comment from Jim Williams on Gearslutz, saying:
"Other benefits are to replace the smaller .1 uf coupling caps with Wima MKP-3's or MIT MultiCaps. The larger mylar film caps can be bypassed with MIT .01 uf PPMFX 630 volts. The HF EQ caps are mono ceramic, 180 pf. Two are used in parallel. Use a Wima FKP-2 330 pf."http://www.gearslutz.com/board/geekslutz-forum/314845-peavey-vmp-2-full-retube-job.html
I'd like to do what he suggests, but my problem is to indentify the according caps on the board. I took some photos of the most prominent caps and an overall picture of the VMP. My hope is, that someone can tell me, which caps can be replaced by better ones.
If you have any other ideas or suggestions, please feel free to comment.
Thank you
Simon
1
2
3
4
5
Thank you
Simon
1
2
3
4
5
