Peter Purpose 2520 max voltage
Seeker
Orlando, Fl
I have a couple of these running in 312 clones, very nice sounding!  I've searched but I can't seem to find anywhere where a max voltage is clearly stated for peter purposes 2520s.  I'm guessing its 18v...  I have them running at +/- 17v now.
According to the original datasheets:
http://www.groupdiy.com/index.php?topic=44738.msg561131#msg561131
2520's can handle up to +/-20VDC.
I think they could handle more but might not be able to dissipate heat fast enough... At least I remember some talk about that somewhere.
thanks for the responses guys... mitsos, I actually found that datasheet, though through another link.  I've been running them at +/-20v for a bit, even before I found the datasheet, just to be safe as these are great sounding little beauties.
I have run them for a few hours at a time like that.... and it wasnt hot enough to cook my eggs... maybe warm, though I didn't actually touch the op amp while it was on....  seemed fine, but perhaps I'll back em off to 19v just for safety...  :-\
I don't understand this sport. Could you enlighten me what the advantage of increasing the DOAs supply voltage might be in a API312 circuit, other then increasing the risk of frying a following unit or the need to pad levels down even further ?
With +/-16VDC supply, these -from API3124 technical data- can deliver +28dBu.
Just a rough check, LOG((((32/2)-2*0.7V)/SQRT(2))/0.7746V)*20+6.02dB from output transformer=28.51dBu seem to confirm this. Your +/-17VDC supply will already give a 29.1dBu max.out. A +/-20VDC supply might further increase this to 30.6dBu.
Seeing FI the +28dBu max.allowed input range of a prism ad-2, not being the flimsyest part around, I don't get the point of the desire to increase the DOAs supply voltage in this context.
There is a TV commercial on US TV where a group of very young kids explain why more is better. This may involve a similar mindset.,
When increasing DOA operating voltages check that operating current density, class A bias, etc are not increasing to the point where dissipation becomes problematic.
Yes, admittedly, I think John got it right... I had in my head to run these close to max +/- simply because I could, without really considering real world benefits.  Just thinking more headroom, higher dbu output, but I hadn't considered whether or not I need it.  Thanks Harpo, for doing the math for me, you are certainly correct once I think it through, there is no real world benefit for me to run these hot.  Even though I've looked at the datasheet, I failed to think about when anyone (specifically me) would actually need >28dbu.
Thanks for reminding me to think about why I'm doing something, not just whether I can or not!
;D
atticmike, do you have an original schematic that shows +/- voltages?  most things I've seen omit the power rails....
Sure, had been doing soul-searching for that project but you'll have to wait couple of hours before I'm able to look it up.
Consider that the vast majority of gear out there runs on the usual +/- 15 V split rail supplies, having output swing that exceeds that doesn't buy you anything. And then you'll have to watch to ensure that you don't clip those +/- 15 V stages with your higher-level output.
-a
