Phantom Power from the Anode?
babyhead
Loas Angeles
Hello-
I am building another MILA and I am pondering the idea of putting a voltage divider after the 90v anode, filtering it with a large cap and using this for 48v.
Any experience with such a design?
Does this make sense?
Thanks-
I am doing 2 channels @ 11ma 300v each and the power transformer is rated at 120ma 250v ct. Do you think that's enough?
I am overbuilding this one to use as a giging bass pre and I want to be able to use a condenser with a pickup so only one channel will be used if at all.
I also want it to work for 40 years...
It took me a while to get to the 48v section of that meta. Its the same problem when I used to pick up an encyclopedia.
I was wondering why I had never seen it in a schematic.
Thanks-
hi all
check this thread, maybe it can help
http://www.groupdiy.com/index.php?topic=3109&sid=78d0da87879b67a04fa2b30d2861c19f
Nice thread. Thanks.
An interesting solution for an abundance of B+...
2 24v zeners after the first filter cap.
Hot.
