Philips-NEFA 2890 - a 1953/54 three-to-one mixer/console
Conviction
Sweden
Hi all!
I recently acquired this gray monster: a three-channel tube mixer/console made by Philips-NEFA for the Swedish Radio around 1955-56 1953-54. It has some features that I don't see much use for, like the commando (talkback) amplifier. Not sure how the designer intended one to use it (see the schematic/block diagram). There’s also a pre-listening function for incoming line level signal. Typical early broadcast feature.
The speaker amplifier (8 & 500 ohms) could prove useful for re-amping etc.
When I bought it I was certain it would be full of Jørgen Schou input transformers, but for some reason the designer(s) chose Unitran E 10E (JS was otherwise the go-to make). The Unitran’s are wired for 50 ohms pri, but has 200- and 500-ohms taps as well. The rest of the iron is Philips’ own creations.
Tube lineup for the preamp section is two EF40’s per channel. The output make use of EL91 in push-pull. Should be able to output quite a high level. Haven’t measured anything yet. Listening amp consists of a EF40 and a EL42.
I’ve slowly started to go through it, replacing dried out electrolytics etc. At some point I think I’ll (have to) change the input wiring, since the isolation is made of rubber and it literally falls apart if you bend it even the slightest.
Also: one of the 100k plate resistors on channel 1, a wire-wound with “bifilar” printed on it, is cracked. Should I replace it with a modern metal film? Or am I missing something here? Wire-wound=stability? What was the intention?
Well, I’ll update this thread once it’s up to par. It’s a nice piece of equipment for sure. Can’t say I find much use for a 3-to-1 mixer though. As is, I kinda see it as a huge and rather impractical (unjustified, space) one-channel preamp.
Some photos (yes, the schematic is glued to the bottom, need to take a high res photo and Photoshop it a little):
Interesting that it's Weston and Cannon P.  Dig the pullout attenuator access panel.  Is that top rear panel spare tubes?
Reportage mixer suggests that was a portable rig , its still quite a lump to carry around Id imagine .
Maybe the 100k resistor is a non inductive wire wound ,  I do know that sometimes special winding schemes are used for this purpose.
Indeed it's a row of spare tubes! Almost a full set.
Yeah, apparently those big Cannons were standard here in the mid 50's. Seen them on almost every ex-Swedish Radio (ribbon) microphone or preamp I've come across from that period. Westons too.
Any thoughts about the plate resistor? Like tubetec I was thinking in terms of inductive/non-inductive. But a bifilar winding method really makes them l e s s inductive... But compared to what? A carbon of that era?
I guess a modern 1% metal film would be suitable?
I think you're right! So. Back then it must have been intentional. But compared to a modern metal film - would it matter? I don't see anything special there around the EF40's.
Yes, portable  ;D 22 kilos. Then add the power supply, which is another 20 kilos. I think it also had a section for plate and filament batteries (and a vibrator transformer) for remote work. Only seen it in a picture.
ruffrecords said:
Very nice indeed. Looks like all B7G tubes.
ian
B7G and B8A (rimlock)  :) Have to read up on EF40's. I would guess they're very similar to their successor, the EF86.
Wirewound was the quietest option.  All the early pro RCA is all wirewound.  If it measures fine then it should be good.
Yes, you are right there are some B8A types in there. I have not seen any of them since the 60s when I used to strip down old TV sets for parts. I checked out the EF40 and according to the Valve Museum it was later developed into the EF86:
http://www.r-type.org/exhib/aad0126.htm
The three reporters could be out of sight, even blocks away. The guy at the console could feed the Kom.-Mik through an amp to the reporter's microphone. Dynamic mikes make OK small speakers. Reporter is told to keep mike near ear. When he hears a tinny "You're on in 3-2-1(clik)" he starts talking.
There would logically be another switch so the reporter mike goes to the console/director, to be sure he was alive/awake and to last-check any details; I don't see that.
  • NEFA-2890.pdf
Hi !
Your philips mixer looks gorgeous and your schematics should be  very useful in bringing my Siemens mixer  back to life .
( which isn´t in such neat condition as your philips , but seems to have a similar design , same tubes etc  )
https://groupdiy.com/index.php?topic=73860.0
Thanks a lot for sharing .
If i don´t ask too much : you  don´t happen to have the powersupply schematics , too ?
Very nice piece.  Thanks for posting the pics.
The first batch of V72 amps (pre the standard Siemens and Halske and Telefunken units) used EF40 tubes before the EF804S was utilised, and the EF40 was itself a replacement for the earlier EF12 used in units such as the V41.
Most of the European broadcast and studio valve equipment of this period was built using wire wound resistors and, although it's a bit of a misnomer, you can still buy 'non-inductve, wire-wound' resistors from places that sell audiophile components if you needed or wanted to replace that 100K.  'Mills'  is one brand I can think of.
Wire wound resistors were used in those days because they were much lower noise than the regular carbon ones that were the only other type available then. Carbon resistors produce a lot of excess noise which is proportional to the current flowing in them. This is why wirewound types are often used as the anode load of the first stage of preamps.
Thanks for the explanation Ian! I know carbons are notoriously noisy in these positions.
One of the 100k (Vitrohm, bad rep) plate resistors in preamp 1 is actually not only cracked, but broken. So it needs to be replaced. I don't know if I should be true to the design/era and find a good wirewound or simply replace it with a modern metal film.
Are there a n y audible advantages compared to a modern metal film resistor? Perhaps wirewound "compete" with metal foil? Is this in the domain of audiophoolery?
The designers used WW only because it was the only choice available to them. I am sure if they were designing it today they would use a good quality metal film. Higher wattage types tend to have lower excess noise so use a 2W or 5W type.
I've got some nos EF40 with no particular purpose, a swap could be arranged. Very cool piece.
RCA stopped using WW by WWII.  I can't think of it in any other post-war American pieces besides some obscure Cinema Engineering and Western Electric stuff.  You'll see it as precision resistors in cathodes for exact unchanging values related to metering taps, not about noise there.
The usual American approach was to used 4x (or more) required wattage, which also reduces noise in carbon.  Normal to see all 2W carbon resistors in lots of American preamps.
