Also check out Enzo's posts here:
AMPAGE Archive - search results
Enzo ( )
Tue Mar 2 01:41:27 2004
I have repaired a couple of the godawful things. I took a piezo disc out of a piezo tweeter. The original disc was two sided, and the metal parts that held it made contact on either side. SOme of the newer piezo discs have three layers, and the outsides are connected together with a separate lead for the center. If you stick this in the old holder, it shorts the two sides together. I had to add a layer of insulating material and a wire to get it electrically to fit. But it works. Sounds like doo doo, but it works.
Enzo ( )
Sat Jul 17 00:10:05 2004
Sounds like the same one as the Sears amp, which they made.
I have fixed those before using a piezo out of one of those cheap tweeters. I carefully broke off a piece ro fit, and it jams down into the mounting little bracket. The basic Moto piezo was a double sided job, so both exterior surfaces were electrically connected. I had to add some insulation since the original was one side each, but otherwise piezo is piezo. They just stick up into the spring windings.
I give them credit for originality, but they sure soiund like crap. If you can't find the Dano drawings, look on a Sears amp drawing. I forget the tube complement.
