Photo sensitive PCB questions.....
I have used ink-jet for burning screens for screen-printing. Just make sure your heads are clean and you are using the correct medium. My epson ink-jet has a setting for transparencies, be sure you have that set correctly too. I don't see why it wouldn't work for photo sensitive boards.
Vetsen
I also use injekt printer with transparencies for injekt and the default printer's settings for this. I always print 2 pieces of transparencies and i use them together one under the other for better results.
fotis
