Pico Stereo build help required!
mOBiTh
London
Hi guys
I bough a Stereo Pico pcb kit (it's at work now but I think I have meter and psu pcbs as well as the main pcb) some time ago, direct from the designer.
Hadn't realised all the help documentation was going to disappear from the public domain (or am I not looking hard enough?)
I'm not sure where to start getting the build information from so if someone could point me in the right direction that would be really appreciated!
I can provide photo proof that I have the new pcbs if required.
Many thanks
Matt
If you bought it from Roger or Wayne, they will provide you with documentation.
Sorry to bother everyone again.
I'm stuck trying to find the correct panel switches for the switch pcb - does anyone have the mouser/RS/etc parts for these please or can someone point me roughly in the right direction?
That would be great :)
Matt
Not sure if these are the ones you are talking about, but from the BOM:
4 Pole pushbutton switch- (Digikey 401-1226-ND or 401-1227-ND) 1 used per channel
2 Pole pushbutton switch- (Digikey 401-1223-ND or 401-1224-ND) 4 used per channel
volker thank you very much! yes those look like they're the ones designed for the pcb :)
they're not on my BOM. hmmn were there different BOMs then do you know?
also i only have the one pcb (with 4+1 switches as above) for my stereo set - presumably the front panel switching is identical no matter whether you're using mono or stereo board sets? (due to the use of relays etc)
