I'm trying to figure out the best way to do this project.
I am wanting to make a piezo to transistor switch circuit - preferably capable of switching a relay. In a similar manner a circuit capable of producing a momentary switching action (normally open to closed and then open again) would be nice too.
This is my purpose in all of this:
I want to make a box that would allow a drummer to plug in a piezo pad to hit, which would switch a relay (shorting + and - DI output of an audio click) to shut off a click (running through in-ear monitors).
Our band (and I'm sure some other bands as well running in ear monitors) need to play to click (either for backing tracks), to allow the drummer to not have to keep time on a hit hat or ride during quiet moments, or for better editing ability in the context of live recording. However, if the band (or the drummer gets away from the click) there needs to be an easy way of shutting it off (and potentially turning it back on).
If I could create a momentary switching action I could also hook up a switch in parallel to the click device's (i.e. Korg Beatlab or Tama's - which seems to always break) tap tempo button. This would allow a drummer to hit a piezo pad to "tap in" timing --- without fiddling around too much with start/stop buttons.
So... I found this http://www.discovercircuits.com/PDF-FILES/PIEZOSWITCH2.pdf
Seems reasonable but I'm unclear if this produces a momentary pulse or latches.
P.S. I know to connect a diode oppose the terminals of the relay to protect the transistor.
Any thoughts?
CC
Any thoughts?
CC
