Hi All,
Just found this forum on the hunt for an audio/electronics guru, im in the process of learning by doing! have a couple of electrical bits that need fixing and figured the best way to do it is to get right in there.
so the situation, I bought a pioneer cdj-400, the seller told me that it was not reading CD's, no problem i thought, I have replaced optical pickups in several device's and as it happend i was looking for one of these players.
so paid the guy and the player arrived, plugged it in to test and the unit did not power up (seller tells me it must have had a knock in the post and he wants nothing to do with it), so I got hold of a copy of the service manual with a circuit diagram and started checking resistance's on the board. What i found was some really dodgy soldering where someone had tried to repair the board before, clearly the seller was lying to me!
one of the dodgy bits of soldering was so bad i removed it and replaced and viola! the unit now powers up, all buttons working the display is working, great i thought! untill i plugged it into my amp.....
the sound output is very quiet and very distorted.... so clearly something else is not quite right....
My question is where do i start testing? can anyone point me in the right direction?
the service manual is http://www.maetech.it/docs/datasheets/pioneer_cdj-400.pdf
any gurus on here care to share what they would do in this situation?
the original problem that i fixed was an issue with the +5v circuit, there was some solder linking the +5 to the ground....
I hope this makes sense, any help is greatly appreciated.
Daz
Daz
