plate reverb electronics
dmp
Madison, WI
Finishing up new electronics for my Ecoplate. These will fit in the original Ecoplate enclosure. Made PCBs using Jim Cunningham's schematics. Added summing for a stereo input to the driver with -6,0,pr +6 dB gain options (as a jumper). And a full bypass of the EQ. The preamps work great - sound good. The driver works well but I don't think I would use this EQ! The HPF with the Sallen-Key is nice but the hi boost and low cut do not do much and the over all EQ is a heavy tilt. I will probably keep it in bypass and use an EQ at my console. I wish I had done a separate bypass for the Sallen-Key as I would keep that in.
