Sorry if I have not been clear.
The use I had in mind is for further filtering of supply to plate voltage, so it should be used in aid (and after) the first Pi filter.
In my FFT scans of the psu schematic I'm actually using, I always end up with the frequency from the diode bridge and the second harmonic (so 100 and 200Hz, or 120 and 240).
Other upper harmonics obviously are not so prominent.
Another one of my main goal is to use this arrangement to
filter the heater supply.
What I'm actually using is:
Diode bridge, Pi filter, LM350 as a regulator -> to heaters.
When current demand is high, I always get the ripple from filament supply coupled in the audio through the ground.
I solved the problem by inserting between the Pi and the regulator ic, an electronic filtering stage.
Actually is a medium NPN (such as BD243) mounted in common collector configuration,
and filtering the (relatively) smaller base current becomes much easier.
I was thinking of substitute the electronic filter with the passive notch (Twin-T).
What do you think?
Respect,
Val
