I have a problem with connecting 6 unbalanced synths to unbalanced mixer. ???
Line is as follows. IIIII unbalanced synths -> (TX) -> unbalanced rack mixer -> DAW Emu balanced input
If I connect just one synth directly (no TX) into rack mixer, all is smooth, just plain flat noise on analyser.
If I connect two or more directly (no TX), there is some slight hum/buzz. Clearly some ground loop.
So I thought I'd connect them all through transformers. But buzz remains, and even increases.
I tried several transformers (Line Level Shifter, Pikatron, little RS), all increase hum. I tried it with all different cable options, no success. All TX I tried had no ground connection between primary/secondary (floating?). Probably this is as it should be, yes? TX were shielded with mu-metal (Pikatron) or in metal grounded rack (isolated from rack).
I must be doing something wrong. Why is it, that I get hum even if I connect just one synth through transformer? One synth directly is clean, no hum. But through TX, there is hum.
Pls help.
Pls help.
