PNMini - Positive-Negative Power Supply Module for Makers
wfsuper
New member
Hello, makers!
I just launched a project on indiegogo. It's a positive/negative power supply module for makers. It uses an innovative circuitry so that positive and negative supply can be integrated to one 3 pin module.
Check it out:
http://www.indiegogo.com/projects/pnmini-positive-negative-power-supply-module-for-makers/x/6711367
It's an idea I had for a long time and I almost put it on every DIY projects I designed. It's very easy to use. One module supports both positive and negative output.
I would like to share this idea with you and contribute to the open hardware community.
