Learner
hey guys,
had bit of a drama today with my testing of the high voltage regulating circuit, it is based on the TL783 data sheet
http://www-s.ti.com/sc/ds/tl783.pdf
I couldn't get any TIPL762 since Farnell was out of stock, so they recommanded the philips BU508AW instead and that's what I got in the circuit above.
http://www.philipsmcu.com/acrobat/datasheets/BU508AW_2.pdf
Without thinking thoroughly I just went ahead and used a 450V 50uF electrolytic cap at the output as shown in the diagram above, and used a 1 meg pot for R2.
Being all excited ready to test the circuit, as soon as I pluged it in I saw very tiny amout of smoke begin to come out of the cap as I proceed to turn the pot more smoke came out. I was stunned wondering what the hell the problem was, so I unplugged the socket but it was too late the cap blew smoke and fumes just gushed out of the cap :shock:
I am just glad it didn't blow my head off or set the house on fire or something, went back and checked on the G9 schematic and I see 100u at the regulator output, in the LA2a it has 47uF in parallel at the DC output.
On the diagram above it only has 50u and the input is 125V, for the G9 and the la2a it is 100uF with output of around 250V, so it seems to me that I would require a 250uF cap (or 3 x 100u cap in parallel, which is what I will use) to be able to cover 500VDC output?
Also, if the value of the output cap at the regulator is bigger then it should be eg. 300uF would that actually adds more ripple to the DC output and therefore defeat the purpose of using the regulator?
I would also like to change R1 to 2.5k in order get 500VDC output
Vout = 1.25V(1 + R2/R1)
Vout = 1.25V(1 + 1.0025M/2.5k)= 502.5V
and placing a 2k resistor after the pot before the ground, any thoughts on that? PRR? Jakob?
I have used 1 W resistor for the whole circuit, does it make any difference if I use 1/2 W instead?
Also, do I need to change the values of the resistors that bias the BU508AW transistors?:?
I am definitely buying an industrial face mask before I will do any more circuit testing, I feel dizzy.......
