clintrubber
For an 'easier' portable 8-track recording setup I'm considering
going Laptop/Notebook.
Note that 'easier' is meant w.r.t. format-conversion: song-projects
from & to main-DAW.
I do have a pretty compact hardware 8-tracker though (Roland VSR-880, 2RU), but
the integration with song-preparation & importing-the-made-recordings-back-again
is obviously not as easy & straightforward as simply just copying the songs you're working on from main-DAW to a laptop (for using in the same software), adding additional recordings and then taking it back and continuing at the main-DAW again.
BUT I thought to have understood that various people have already taken that route
and regret it in a way - as in the hardware recorders being just so more easy to
work with 'in the field', more reliable, less hassle & computer-surprises etc.
'Easy' is also meant w.r.t. simplicity of setting up, but I guess that will be comparable
for a laptop to the hardware boxes: in both cases you need to have a few rackunits,
either as additional mic-pre's to the VSR-880 or as the audio-interface to the laptop
(I have already a Phase 88 FireWire interface, so that'd be just one cable to an eventual laptop).
Any thoughts ? Experiences ?
Peter
from & to main-DAW.
Peter
