YannLu Well-known member Joined Aug 21, 2016 Messages 85 Location Belgium Aug 9, 2017 #1 Hello, I am looking for a while some dual gang pots 9mm (Alpha type or Bourns PTD90 series). Value: 50K reverse log. And they are very hard to find... :-\ Thank you for your help ! Yann
S sahib Well-known member Joined Aug 19, 2006 Messages 4,051 Location Glasgow - UK Aug 9, 2017 #2 What is your application?
YannLu Well-known member Joined Aug 21, 2016 Messages 85 Location Belgium Aug 9, 2017 #3 Parametric EQ in 500-series. I need the value 50K.
RuudNL Well-known member Joined Apr 26, 2009 Messages 3,279 Location Haule / The Netherlands Aug 11, 2017 #4 Can't you use 100K dual reverse log, and use half of the value of the capacitors? (IMHO 100 K dual reverse log is much easier to find!)
W wlinart Well-known member Joined Jan 19, 2012 Messages 290 Location Belgium Aug 13, 2017 #5 This won't be the best quality, probably, but it looks like the right thing: https://nl.aliexpress.com/item/Japan-produced-TOCOS-9011-type-sealed-double-potentiometer-C50K-copper-handle-15MM-flower-with-a-step/32790255890.html
YannLu Well-known member Joined Aug 21, 2016 Messages 85 Location Belgium Sep 13, 2017 #6 Thank you. I found that on Mouser: http://www.mouser.be/Search/ProductDetail.aspx?R=PTD904-2015K-C503virtualkey65210000virtualkey652-PTD9042015KC503
