Pots, Switches and Push button recommendations...
abbey road d enfer said:
Something like this?
https://fr.rs-online.com/web/p/products/8633538/?grossPrice=Y&cm_mmc=FR-PLA-DS3A-_-google-_-PLA_FR_FR_Interrupteurs-_-Boutons_Poussoirs_Et_Accessoires%7CInterrupteurs_%C3%80%C2%A0Bouton-Poussoir-_-PRODUCT+GROUP&matchtype=&pla-461760784297&gclid=CjwKCAjwuO3cBRAyEiwAzOxKsiPfrckvHHyEaoBsS4ljsakFBS9WSYsKirNXCCKTmWQ_sZm9K2BDwBoCBcIQAvD_BwE&gclsrc=aw.ds
or
https://www.amazon.fr/Bouton-poussoir-encastrer-lumineux-Cosses/dp/B01AQRW2MK/ref=sr_1_14?s=hi&ie=UTF8&qid=1536931182&sr=1-14&keywords=bouton+poussoir+lumineux
The problem with those that are nice looking is they are usually very expensive, typically about £20. Most of them are not very good at passing audio, so you need some logic and CMOS switches (or FET's, or relays).
merci mon ami...the square one looks decent...that brand also makes another decent looking option...
mmm yes I have found them to often be expensive also...another option is to use a low cost push button switch and a separate LED...
I have been searching and not finding the following:
Latching pushbutton DPDT ON/ON for panel mount about 11,7mm diameter.
All I find is for PCB mount.
It's for a PRR-176 frontpanel from Collective Cases.
Anyone knowing where to look?
