I've built a couple of tube amps and am going to have a go at some discrete solid state amps with crossovers soon.
One of the pieces of test kit one needs is a good load box.
Not a good idea to power up a tube amp with no load. And it's very nice to measure amp performance with your real time audio analyzer system (RTAS).
Basically it is a high power dummy resistance connected across some input speaker terminals with an additional parallel high-resistance voltage divider. The RTAS output is taken across one leg of the divider.
So, I'm starting this thread to gather opinions on how to make one better than the one I made
Please feel free to provide your inputs.
The load box needs to have speaker level input connectors and should also have an output which allows you to connect a suitably attenuated version of the input signal to an RTAS for detailed observation of the amp under test performance.
The attenuation of the RTAS output should be variable so that different input power levels can be 'mapped' to the available RTAS input voltage range in sensible ways.
So features which can be provided are :
- aluminium enclosure for heat dissipation
- input speaker terminals, output speaker terminals, balanced RTAS output connector
- non-inductive power resistances for dummy loads
- switch to select dummy resistive or speaker 'thru' as the high-power load
- switch to select different dummy resistances ie. 2ohms, 4ohms, 8ohms, 16 ohms
- switched variable RTAS output level with mute
And something I'd like to try as well is a switched defeatable filter for removing the excitation signal from the RTAS output. So that when you observe the amp signal on the RTAS, the test tone is removed. Not sure how this is properly done so that one can see the aggregated distortion components on the RTAS.
I'll put up my primitive schematic shortly
