robomatique
Hello,
As standard most racks have their power inputs on the right hand side, looking from the back. I like this standard because it makes it possible to have all the power leads down the left side, and all audio wires down the right side of my rack.
The problem is that most power switches on studio gear is on the right hand side of front panel, so I have to run the 230V cables across the chassis and back again... not very good? Note that most hifi gear has their power switch on the left side...
Even some PCB layouts (like the beautiful G9) makes it easier to put all torroidals on the "wrong" side of the chassis, which makes sense if you think of the power switch, but not if you think of power inlet into the chassi.
The problem is that I just got a chassi made for me with the power inlet on the standard side, and noticed that I have to pull the cables back and forth to be able to connect it all. ANyone has got a nice solution, or similar problem?
THanks
Robert
THanks
Robert
