Marco Pancaldi
Active member
- Joined
- Feb 19, 2006
- Messages
- 36
I need to build a mixer/fx send circuit to mix some line level signals (line out from a guitar POD with external delay returns).
The total circuit will have 4 5532 opamp.
The unit needs to be stompbox size, with external supply, unity gain. Less the components, the better.
But I will probably implement simple balanced input and impedance balanced outputs, and I'd wish good headroom.
I can build the internal power section as a guitar pedal, with 1/2 voltage used to bias the non-inverting inputs.
Or, I can implement a bridge double voltage circuit, using two diodes and caps. This version have the advantage to double the voltage (my regulated pedalboard adapter put out 9 or 12.5 volt), extending the headroom, but with lot more ripple...
Needs advice and maybe some schematic as reference.
Many thanks
m.
Many thanks
m.
