juniorhifikit
I have a DDA DMR12 console power supply that needs repair. It's supposed to output +-18volts and 48volts for phantom. It's an interesting circuit in that the regulator is a separate board with discreet components - not a monolithic regulator. Here's the schematic:
http://www.scottgreiner.com/DMR_12_PSU.pdf
Basically, after rectified and filtered there's +-30volts at the emitter of the power transistors, and about the same (from the regulator) on the base. So not much current flow there which equals no voltage output (collector). Obviously there's something wrong with the regulator circuit.
Caps and resistors are fine, so I'm going to swap out all the diodes and transistors on the regulator board. My problem is finding the correct parts. There are so many cross-references, and electronics supplies are a little limited here in Paris. Does anyone recognize these components and know of their common cross-reference names/part numbers?
1N 4148
1N 4002
TIP 31
TIP 32
BC 212
BC182
BC 441
2N 5322
Thanks in advance!
1N 4148
1N 4002
TIP 31
TIP 32
BC 212
BC182
BC 441
2N 5322
Thanks in advance!
