Siegfried Meier
Hey guys,
I have a Behringer Rev2496 here with a bad power supply. It appeared that 2 resistors were burnt out, so I replaced those (with standard size, mind you, not SMT). I'm measuring the same voltage on the output as a known good supply - 30vdc, 5vdc & 15vdc. However, it still won't power the mainboard.
What could I be missing here? I've noticed that on the good supply, there's a 100pf cap that seems to be melted to one of the smt resistors (same as the one I changed in the bad supply). This would appear to NOT be good, but this power supply works fine.
How can it be that I read the same voltages, but this one does not work?
Any help much appreciated.
Sig
Sig
