Hiya Chaps,
Been doing an awful lot of reading lately, with regard to designing /DIY'ing some power transformers. Been reading up on the B.B. Babani - Coil design and construction manual / Wolperts's design manuals, and the Excellent Pat Turner site (although they are a mix of bloody imperial or Metric !!)
http://www.turneraudio.com.au/education+diy.html
Anyway,
I've been drawing up my notes, And i will put them up for scrutiny,but firstly,there are a few questions I need help with answering.
here's what i'm after. ( briefly, i might add)
230V Pri ( 2x115V),
250 - 0 - 250 V @100ma (SEC1)
6.3V @ 2A (Sec2)
5v @2A.
Now,
My first question is , on the SEC1, do I design around the Babani way, which states - only half the sec HT winding, supplies current at one time, eg,
So my total wattage would be
250x0.1 = 25W
6.3x2 = 12.6W
5x2 = 10W Total VA = 42.6 , or,
500x0.1 = 50W
6.3x2 = 12.6W
5x2 = 10W Total VA = 72.6
obviously, this is before using,
** add 10% for losses **, and
**Use core with 33% higher rating ** ( Pat Turner)
The Babani book , is the only place I've read about this ( I can see that only half the winding will supply current at one time), but does it pay to be this 'tight' when designing transformers. ( maybe, the extra manufacturing costs)
I would have thought , that the transformer, would be designed around the 'whole' winding.
Question 2.
When measuring the magnetic length of the E/I stamping, is both windows taken into account ? eg.
if you can imagine the stamping, I've been working it out based on one 'window' of the E/I stamping, not both sides......if you can understand what I'm on about....
I've gone through a load of examples, but I'm still not quite sure on a few things......
Made a great contact last week, with regard to a small ' cottage' transformer manufacturer, and I got to call around there this week - So I'd just like a bit more knowledge, before i give them a call.
Also, what is the design criteria for C Cores ?, is it the same ?, it's just that i can't find out that much, with regard to DIYing them.
Cheers my Dears,
Steve :thumb:
