Power transformer for Green Pre
bapiano
Member
Colorado, USA
While waiting for PCBs to arrive from Peter I've been thinking about what power transformer to get. I think that I've seen mostly the Dagnall D2035 in photos I have found. Is this what most people are using? Is Peters PSU designed around this transformer?
Does anyone use a toroidal with this unit? I read the thread on pros/cons of toroidal but have one in my Hamptone and know that they are used in many other fine mic pres as well.
Nice coincidence, right now I'm also looking for which trafo to get for a pair of Green-channels.
That DG2035 is a 6VA unit, 0.2A per winding, has it got enough oomph ?
Joe's (JLM) estimation was around 90mA max per Green-channel
(for the 5532's & some mA's for the NPNs, so excluding additional stuff like the LED-bar etc).
Regards,
Peter
They've got the 14v ones but no 28v are left.
Would the 14v run a 2 channel Green ok? Seems like it should if that little Dagnall 6v can do it.
Bryan, how many channels are you powering with the 28v 'cheap torroid'?
Here we go again :grin:
I like to allow 100mA per channel for the Green pre, so each channel will draw 30V x .1A = 3VA. The 6VA will work but I'd advise using a 10VA transformer for 2 channels to allow plenty of headroom.
Peter
