I have recently completed a tube limiter build, everything works as expected but strangely the power transformer gets a bit hot (around 45 deg C / 111 deg F)
The PT is way oversized, the 6.3V tap and HT tap are twice the current rating that is required for this circuit, in fact I added resistors to the 6.3V output because without those the voltage was more like 6.8V
I just used this transformer because I had it laying around unused. Since it had plenty of headroom I thought the transformer would run cooler, not heating up.
Also expected there should be less hum radiation because the transformer is not operating near the limit, but in fact I quickly swapped a smaller transformer and there was 10dB less noise in the audio path.
Doing some research about the subject I found out that transformers can generate extra heath also when they are underloaded. I thought this would happen only when the transformer is overloaded.
It seems the transformer should be able to live with this kind of temperatures, anyways I would be interested in knowing your opinion about this.
