I recently bought an Antek 325v toroidal power transformer. I'm just wanting clarification I have my wiring correct before applying voltage.
Here's what I believe is correct :
#1 Wire the primaries in parallel for 110v.
#2 Wire the 325v secondaries in parallel for 325v 0.8A. Which would be yellow to yellow, and white to white, the white then goes to ground?
This is for a preamp I'm working on. So, the 325v will then be rectified, filtered and the voltage dropped before being applied to my preamp stages. The 6.3v secondaries will then power my 12AX7 heaters.
