industrialarts
- Joined
- Oct 1, 2020
- Messages
- 130
I have a Fender Performer 1000 on my bench with a bad power transformer. It seems the transformer is no longer available (PN# 027668) but it's a simple 120vac single primary CT secondary, 30-0-30vac. So I could spec a replacement but I do not know how to calculate the current / VA of the transformer.
The internal fuse is 4A so let's go with that as primary draw (which should be overkill) Since Vs/Vp=Ns/Np=Ip/s then Vs/Vp=Ip/Is and if we take Ip as 4 then does 60/120=4/x solving for x = 8A? I think I did the math right but that intuitively seems wrong.
I know there are smart people here so any help appreciated. I did google the part number and found nothing available after about 15-20 minutes of searching
