powering multiple PCBs
morls
Australia
I'm putting together a transfer console, and need some advice on how to power 6 PCBs from 1 power supply. The total current drawn is around 1A, and the switching power supply specs are 52.8W, 24V, 2.2A.
The power output is V+ and V-, and each board also has V+, V-. Would something like this do the job?
Stephen
It's hard to give an answer if the manufacturer doesn't give power ratings for the PCB's. I use Phoenix DIN rail terminal blocks for this. They can be configured to bus as many signals together as you need. I use Phoenix UT 2.5 MTD blocks. You also need to buy the Bridges to bus together the blocks.
