Preamplifier's universal input board building info/support
Help Support GroupDIY:
Israel
22uf 16v will be fine. 1uf input capacitor can be 63-100V, poly, Wima etc.
Yes, DI booster will work on +18 as well, with less output swing. Not sure every 24V relay will work on 18v btw...
Possible to check how many volts do you have on rectifier capacitors on power supply,
if + is more than +29V, it is possible to add +24V separate regulator, LM317 and some parts will do the job.
The board dimensions are 81x54mm.
Israel
Farnell seems doesn't have switches with nut, but these will fit:
http://il.farnell.com/multicomp/1ad1t2b4m7re/switch-pcb-dpdt-on-on/dp/1550173
http://il.farnell.com/c-k/e201md1av2be/switch-dpdt-r-a-pcb-on-on/dp/1437795
http://il.farnell.com/multicomp/1md1t2b4m7re/switch-pcb-dpdt-horiz/dp/9473319
noulou
Athens, Greece
I wanted Igor and anyone who wants to build this board know that the relay-driving transistor for the DI is marked upside down on the boards silkscreen.
So if you're planning on putting a pn2222 or 2n3904 NPN in there, put it upside down.
Nikos
radiance
the Netherlands
I'm going to use these for my api 312 build but I realize that the 312 has plenty of gain, so no need for boosting the line signal right?
I might just route the signal coming from the line input jack straight to the input transformer of the 312.
Or am I missing something?
EDIT: Duh...just realize it's a High Z input...
Never mind...
letterbeacon
London, UK
Does this DI add any colour to the signal at all?  I want to put it in front of a DIY 1290 but would like to keep the colouration of the Neve without adding to it.
dmp
Madison, WI
How would one answer this question? I used this for my ez1290 project and it sounds great with a Precision Bass, which is all I've used it for, but i haven't done any 'colouration' tests...
mrcase
vienna
Hi!
does anybody have a mouser / farnell link to which relay and which input jack fits the pcb?
and which is thte best substitute for the  BC214C??
cheers
Winnipeg Mb Canada
Use a socket to try different transistors and use the old method of putting
a regular d.i. into the mic input to experiment with different combo's
[ it would be like using a countryman d.i.  - fet  - into the mic in ]
madreza
Paris, France
Hi Igor,
I've gotta be missing something !!!!
I bought 10 DI's from you and have the same probleme on all 10 :
No Signal
tried feeding them with a 1Khz Sin , checked with Oscillo
I have a signal till the G pin of the J111 .... nothing further than that !
any idea ?
Thx
dmp
Madison, WI
No Signal
any idea ?
Thx
I'd suggest you check that the bias on the G of the JFET is correct - should be about 12v. If not, you have a resistor wrong or a diode backwards.
If that is correct check that your pinout of the J111is correct for the pcb.
I've built these and they work - so you have a problem somewhere.
dmp
Madison, WI
Then pull the JFET and see if the voltage becomes correct. Problem may lie with your J111. Maybe the pinout is wrong or it is a bad part?
Look up the datasheet for the J111 you bought, verify that the pinout is correct for the PCB.
madreza
Paris, France
Thanks DMP for your help
In fact Igor Sent me a K170 instead of a J111
the pinout isn't the same and I didn't check that :D
now it works great !!!!
