nkefaloyannis
Member
Hi all, I just built a DIY summing mixer with a NEUMANN V475-2A card. What I found during calibration and check, is that although the 1st channel works as expected. i.e I feed the input with a 1kHz sine at balanced line level -18DBFS through a pair of 5.1k resistors as Re, and I 've installed a stereo 20k linear for Rg. I get 0db unison when the pot reaches 6.2k and I can get headroom from -12db at 0Ω, all the way to +12db just over 15k. I understand that is correct and according to Neumann. On the 2nd channel though when Rg reaches +3db I am starting to get clipping, and just over +3db the output starts to fade down, like something overloads the amp and it shuts down. It seems to me, like a degraded or burnt component somewhere on this channel, or maybe something is wrong with the bias of the amp, but as I don't have any knowledge on electronics- I am a sound engineer myself- I wouldn't know where to look or what to measure with a multimeter or even replace. I thought of asking the community, in case someone happens to know the insides of these cards and can direct me in some way.
Regards,
Nikos Kefaloyannis
Regards,
Nikos Kefaloyannis
